Principles Of Refrigeration - R Dossat - Solutions to the problems?
Hi, im currently working through Principles Of Refrigeration - R Dossat - SI Version. Does anyone know where I can find the solutions to the problems set out in the book please?
Many Thanks
Craig
Re: Principles Of Refrigeration - R Dossat - Solutions to the problems?
The older versions had the solution directly after the example.
I have the second edition and at the end of each chapter is a series of problems but no solutions?
I have a copy of Wiley International Edition 1961 (IP- version) and after each chapter there are examples i.e. problems/questions together with answers ...
Best regards, Josip
I think the 'solution' is to absorb the knowledge of the relative section to understand the answer/result.
Go to the back of the book there is an Answer key from page 443.
Rob
You make it to easy Rob, if they can't read the instructions what hope is there?
Brian_UK
Sorry
:o
Rob
Thanks for your replies, but I have been through the book and I cant see the solutions anywhere! No answer key from page 443, no answers after the problems as there are in some editions. Mine is the second edition - SI version though.
I have tried to my best to read and absorb the knowledge as suggested but I just wanted to check I had understood it correctly.
Many Thanks
Craig
