Re: Indoor Unit Not cooling
are you sure the units are wired and addressed correctly
is the gas charge correct
martinw58
Gas charge and setting are all good and well and rest of the other 5 units are working fine.
How did you checked gas charge?
Do you hear clicking noise when energizing indoor units that are not opening valves?
The air filter might be clogged. because clogging air cannot flow through properly which greatly reduces the cooling capacity of the air conditioning.
Sound like a wiring problem to me.
Check the wires again to make sure it is correct.
3 units not working is not likely to a manufacture problem.
