Please suggest Suitable compressors
For 27000 litres i need to achieve -20deg air temp. Please suggest suitable compressors that achieve the same in a single compressor or maximum two compressors. The available compressors in the Indian market are Danfoss, Tecumseh, Emerson. Please suggest a suitable model. Much obliged. :cool:
Re: Please suggest Suitable compressors
Do you know your cooling load?
Volume alone does not determine system capacity - there are many other variables, eg. Room dimensions, door openings, personnel/equipment operating inside, panel thickness, product load, ambient conditions, pipe length, lighting, to name but a few..
Hopefully these help:
http://www.ipu.dk/upload/teknologiud...lpack_1.50.exe
https://opi.emersonclimate.com/OPI/d...ad/Boxload.zip
https://opi.emersonclimate.com/OPI/d...S/PSSsetup.exe
Cooling Load - 5 kw
Room Dimension - 10 x 10 x 10 feet
Door opening - 4 x 8 feet
Equipment operating inside - 4nos washing machines will be placed at a time
panel thickness - 125mm
Ambient Conditions - 24 deg c
Pipe length - 25 feet max.
Please suggest any particular model or specifications of compressors i should look for. Thank you
Washing machines? Operating at -20°C?
Use the links above.
They will point you in the right direction.
We are in the process of building a Walk in Environmental room for a consumer electronic R&D firm. So they are going to place washing machines and refrigerators inside the room.
