Small Geothermal Heat Pump
greetings to those who know more than me & are willing to share it;
i would like to put together a small geothermal heat (only) pump using a condenser unit such as used at a supermarket for food. the complete unit, except for the txv, ***** to water exchanger & circ pump, would be totally enclosed in the discharge of my whole house air filtration system (approx 200-300 cfm). the small fan would be removed. available well water is 57f, though would like capabilty of +/- 10f. prefer 3000-4000 btu (already have two ton geo heat pump). any suggestions?
thanks much;
eddc
Re: Small Geothermal Heat Pump
i know sth about geothermal heat pump, but what you said is not very clear, i am not able to check out your meaning.
any one more suggestions?
i guess i would like some direction on which is best; a low, medium, or high temp condenser, type of refrigerant, rough size / type heat exchanger. i can vary air & water flow; txv should take care of *****.
would like to get things right the 1st time. geothermal is getting more popular & a small constant heat output is preferable to one that cycles on / off.
my air filtration fan runs 24/7 & is quiet. it only makes sense to tie both of these together. aim is to save money, though i don't mind spending $ to accomplish it, also enjoyable to try new things. i've tried electric, wood, hot water & solar, next logical step is geo.
appreciate;
eddc
EDDC
i guess i would like some direction on which is best; a low, medium, or high temp condenser, type of refrigerant, rough size / type heat exchanger. i can vary air & water flow; txv should take care of *****. eddc
Sounds like an interesting project.
I'm working on a very small water-in-water-out heat pump project myself.
I have made a test unit out of a used dehumidifier compressor and two heat exchangers. I have done some initial testing and have photos and performance graphs to share.
My plan is to develope a small ground-source/solar-assist heat pump that I will use to heat a hydronic floor.
My research & testing indicates that this is the best way to go.
I have plenty of information to share and many more questions.
Regards,
* lucky-old-sun *
Hi Lucky and welcome to the forum.
i am working on designing of brine to water heat pump, the geothermal combined with solar heater will be a trend.
