Hi all,
Is it now an fgas requirement to use proprietary flare adapters?? Got a bit of a debate at work as to the new fgas requirements. Can anyone with a recent C and G fgas clear this up for us?
Craig.
Hi all,
Craig.
Can you elaborate?
What's a flare adaptor?
The braze on pre made flares, they look machined from solid metal.
I would have thought if it was a regulation then equipment manufacturers would supply flare adaptors to be used instead of traditional flares? Personally I prefer flare adaptors, although even these can leak if your not careful when fitting the copper flare gasket. Ideally though everything should be soldered connections - no more flaring!
Just to clear this one up, the adaptors are reccomended as good practice, but not a statutory requirement. Had s look at a CITB fgas course book.
