hi,i'm thinking of buying a parat roller case to use as my day to day service box,the only thing is they are on average £180 pounds stirling!! just wondering if anyone in the uk knew of anywhere to pick them up a little cheaper?
regards ali.
regards ali.
What luck have you had in your Google searches for a cheaper find?
Hi aliman
I got mine from RPW about £170.
Expensive I know but well worth the money, if you look after it it will last you a life time.
PP
Thread moved to the correct section
hi,cheapest was £182 from amazon for the classic roller.
thanks p_p, i must go into rpw, gloucester to do a bit of bartering.as i did'nt know they stocked them!
Ali
Like I said look after it and it will last you a lifetime, which in the long run makes it a cheap case.
Go on you know you can afford it!!!!!!!!!!!!
PP
I dont think they stock them anymore but they will be able to get hold of one for you, as RPW nottingham did for me.
PP
