Friends i have a problem to connect a york millinium recip. Chiller to my pc.
Any one have any idea for this!
Which software can be use to resolve this problem.
Infact! I want to monitor and control this chiller from my pc at rs485 network.
Hi ALLAHHOOPK
Firstly what is it you require the PC to do with the controller? If its to act as a simple time clock then you can interface with relays through the remote start / stop line, if you want to control setpoints etc and use as a repeater panel where you can monitor remotely then you'll probably need a BACNET , MODBUS, EMS type interface
Dear i don't know the software, which can be use to connect the chiller miro board. Interfacing is the second step.
Thanks with regards.
