Hi everybody.
I need to do some maintenence on a HSW3122 McQuay Screw compressor.
Where can i get info with torque tightness values in PDF format.
Thank you in advance!!!
Hi everybody.
Which part of the compressor are you tightening
Hi GAHZ,
It is a change oil and filter maintenance. So I need filter cover, oil drain and filler plugs.
Thank you!!!
Hi oil filter cover 60nm
13 litres of ester 68 oil
Vac the oil in from drain valve ,Which is 1/2 flare
Thank you very much GHAZ.
I still need oil filler plug tightning torque to retight and eliminate a very small leak and oil residue.
Can you help me with that?
Thanks again!!! (Y)
