1 Attachment(s)
Heat Pump problem. How can I solve this? What are the steps ?
Attachment 11780
I was trying to solve this as part of my preparation. But don't have a clue as to how to solve it. What are the steps ?
Re: Heat Pump problem. How can I solve this? What are the steps ?
You have to work out the temperature of the brine leaving the bore hole collector.
mad fridgie
But, What is the use of of ice thickness on the bore hole collector pipe ?
your ice acts an insulator,
mad fridgie
Thank you for your reply. So do I have to assume the temperature difference in the borehole ? and would 5 deg c be reasonable?
How do I get the ground temperature which is needed to find out the evaporator temp. ? I'm very confused..!!!
Can you please provide me with a step by step solution. That will be a great help...Please..!!
