Hi every one,
I just took some temperature and air flow readings at my indoor "A" coil. The vapour line temp
seems high.
Do these numbers look OK or do I have a problem?
pilko
Hi every one,
seems high.
pilko
It may be but what is the refrigerant as the temperature on it's own does not relate to anything?
Thanks for the response Brian.
The refrigerant is R22.
pilko
Discharge does seem a little low, but this just could be down to losses, from comp and piping.
Is frost on out door unit fairly/ice even when running
But looks OK
