Re: Hotpoint Mistral Plus
Hi Andrew and welcome.
You can also try http://www.ukwhitegoods.co.uk for information on domestic items.
This link is for Hotpoint instruction booklets but you do need a model number, I'm trying to find out where they are ;)
http://www.hotpointservice.co.uk/hs/...l=&d-16544-o=1
edit:
Found a download, pdf here...
http://imagebank.indesitcompany.co.u...ion/HB8496.pdf
Hope it helps :)
Brian.
That's one hell of a referance library you have there. Either that or the processors in your servers are Co2 cooled!
Grizzlyhttp://www.refrigeration-engineer.co...ons/icon14.gif
Yep, I must trim down the 'Favourites' or 'Bookmarks'; they're getting out of hand ;)
Hi Andrew, I also have a Mistral. On mine there is/was a label on the back which fell off some time ago. However today, whilst trying to fix a non working fridge compartment, I noticed that there are further labels behind the salad drawers in the fridge compartment. By the way, -22 degrees is the correct default setting for the freezer on these units...
If you want to change the temperature on the freezer anyway, select the freezer on the display, then hold down the temp button. This will cause the display to cycle through the available temp settings. Release the button when the desired temperature shows and then press the save button to store.
Dave
Thank you all (particularly Brian) for your help. I have downloaded the manual Thank you.
Andrew
