Sporlan where are u?
Ive just repaired a condenser coil on a Mitsi which had a leak on the ends due to rubbing on the metal holding plate. Anyhow due to it being a pain i crimped and isolated that part of the coil.
Theres a distributor that has 6 pipes which feed from each section of the coil and feed the liquid line before going through an accurator to the evaporator.
How much condenser capacity will i lose will it be 16%? and what difference will it make to the head pressure.
Also is it true that Japanese equipment is designed to run at higher head pressures due to the difference in ambient design.
