Re: Deep in thought on R134a
The pressure may equate to 130°F but I very much doubt if your system temperature rose as you added the nitrogen.
By the way is this worth pursuing in light of the illegal activity involved? :D
That is my point exactly. The system temperature stayed at 50 deg F. That is why I am saying the 134a should condense due to the vapor temp and pressure.
The way I understand Daltons law is that if you just have refrigerant vapour in your system then adding nitrogen will not make the refrigerant condense. The law states the the gases will act as if they occupied the space on their own. The refrigerant wont condense because there are too many nitrogen atoms in the way so the refrigerant molecules can't link and form a liquid.
Therefore the R134a wont condense mearly by adding nitrogen. The only way to get it to condense is to reduce the volume of the system (not likely) or add more mass of refrigerant until you get the system pressure to reach the saturated temp/pressure for the system temperature.
I suppose theoretically reducing the ambient around the system enough (a lot for your example with 5-8lbs in) would cause the refrigerant to condense.
I think my theory is sound. Watch this space!
Andy.
3 Attachment(s)
Thanks Tayters, in your discription I picked up on something that sparked a vision of what is taking place inside. The refrigeration circuit is for all practical purposes a single shell (albeit overlooking the piping) and as such, the two gases do occupy the same space. Their molecules are intermixed among each other. Here is a link to describe the gases with images. I now fully understand and thanks Tayters for jarring MY brain molecules!!!!!!!!!!
http://www.ausetute.com.au/partialp.html
Also here are some images from same website.
