Industrial Refrigeration Design
My company is considering a plant that will involve design of a large propylene refrigeration system (>8,000 tons @ -35 deg.) with several evaporators.
Would anyone care to mention some names of design firms capable of designing such a system? Perferably, but not necessarily, based in the US.
Thanks,
Re: Industrial Refrigeration Design
J&E Hall, Based in england.
Regards,
Guapo
try star refrigeration in england as well.
Hi, u856684 :)
welcome to RE forums...
u856684
Thanks,
Can you describe a little more all about your plant ....
....... :confused::confused: >8000 tons at -35* ( deg F or C) .... petrochemical plant or something other.... thanks;)
Best regards, Josip :)
Hydrocarbon systems, especially large ones such as yours should probably be built by the equipment manufacturer who has the most experience. I can't speak for the international market as I am not very familiar with all of their capabilities.
However, here in the US the two names that come to mind are: FES or Frick. If you would like some contact names, please let me know.
This project sounds similar to one I worked on many years ago, but mine was only about 6,000 HP. Yours will be considerably bigger for that capacity and temperature range.
Bonar Engineering did our Brewery ammonia system which was commissioned last year. It's +15F ammonia at 5K hp, came up easy and is running well. Good service from design to start-up from Hank and company and no complaints so far! Google Bonareng.com
Sorry for the sketchy information - we are in the conceptual design phase. Call it 8,500 tons @ -35 F (-37 C) for a petrochemical site in the US.
Also, on the other response, I have previously understood FES and Frick to design much smaller units than this one.
Thanks,
I would talk to J. Borg PE at Carbonyl.
He is an expert in large refrigeration design for petro chem facilities, and based in the Baton Rouge area
send me a note and I will give you his phone number
Bruce
u856684,
I talked to FES about your application. They did say they would be interested in discussing this project further. They have packaged centrifugal compressors as well as screw, so you have a choice in what you might want.
If you want to pursue this, let me know and I can pass along the gentleman's name.
try gea in england
they have a division for petrochemical that used to be technofrigo and are very experienced in large installations.
u856684
Thanks,
hi this :o:o
My company is possible with good track records. York International (Base in Singapore), some plants that we have Exxon Mobile, GSK and a few others. PM me if you are still looking
York can probably design a system of this type.
BT Builders Inc
Pompano Beach, Florida
Kamm Consulting, Deerfield Beach, Florida
u856684
Thanks,
Hi Thomas:
Please check message date. This is almost one year old. Sorry.
Josei
hello
our company is constructing 25 mw power plant with natural gas fuel (engin generator).
we want to use of our exhaust heat for having industrial refrigrator_ 2 refrigrator 1.(5 c )2 . (-30 c)_
and because of envirment we want to use nitrogen instead of ammoniom.
can u give me some information for this system.
with best regards
sepideh
Hi, sepideh :) ,
sepideh
hello
with best regards
sepideh
this is a very strange idea to make an industrial refrigeration plant with nitrogen as refrigerant .... OK, we use nitrogen, but for very special purposes in a freezing tunnels ...
in another hand ammonia is natural gas (green and very cheap refrigerant) and I can strongly recommend you to use it .... you can build a very nice plant with a very little amount of ammonia without any harm to environment ... energy saving plant to leave something good to your kids....
... , but let's wait for some other valuable comments ....
For a large R290 system, your best bets are GEA-FES Systems and Frick (York). Frick (York) is stuck with the York Turbomaster for a centrifugal; however, FES can go to the API compressor manufacturers for a true industrial compressor. A thrird option would be Enterflex (formerly Toromont); however, they are concentrating on gas compression and letting the refrigeration syatems pass by. They also have very few large industrial systems people left. The ones with the most experience and technical personell world wide would be FES and Frick.
Wagner Meinert would be interested in helping you with your design and installation. Contact em when you get an opportunity to discuss. We are a large mechanical design build firm.
If you seek a design consultant in industrial refrigeration plants , 60 years experience , professional criteria , the better . . . George Briley , P.E. , of Technicold Services , Inc. , http://retaaz.com/retaazphx/gcb/about.htm
TECHNICOLD SERVICES, INC.
8727 Huebner Rd - Apt. 315
San Antonio TX 78240
Phone: 210-340-0664
Fax: 210-340-0369
Cell: 210-274-7717
email: georgegcb@aol.com
email: georgegcb@sbcglobal.net
The biggest refrigeration company in North America with over 7000 artificial ice rinks installed, Olympic slides, industrial refrigeration 10000 tons and more, Ammonia and other refrigerant ,direct and indirect cooling system ,
Ground freezing, meat plant, brewery, Dairy, refrigerated warehouses, Petro chemicals etc...
CIMCO REFRIGERATION
65 VILLIERS STREET,
TORONTO, ONTARIO
CANADA
M5A 3S1
TEL: 416 465 7581
fax 416 465 8815
http://info.cimcorefrigeration.com/
