Digital Scroll Technology
Has anybody any knowledge about this?
As I understand it, Copeland has a solenoid valve that changes the axial compliance from no compression to full compression and a controller that cycles it for temperature control.
No modulation, just on and off cycling.
Re: Digital Scroll Technology
Digital Scroll systems Is it energy efficient both in terms of Connected load and power consumption, as many Utility company charges for connected load in addition to actual power consumption.
How does it compare to Chilled water system especially in power consumption.
The axial compliance in scroll compressors consist in applying pressure on the orbiting scroll so that the lower flanks press on the fixed scroll (and that scoll's upper flanks press on the orbiting scroll) so that little leakage occurs. The device that applies the force is a movable seal that is pressurized through two ports midway between the scrolls. If this seal does not pressurize, the scrolls will move but the leakage through the flanks is high and the scroll does not compress. What the digital scroll has is a solenoid valv that intercepts the pressure of the scrolls and feeds it to the floating seal. Giving the solenoid an electrial pulse train will cause the scroll to compress while the seal is pressurized only. The advantage of this method is that the refrigerant that flows from an inner pocket of the scrolls is discharged to the neighbour pocket outwards and not to the suction pocket, therefore saving work because you only loose the work done between the outward pocket and it's inner neighbor. This is all explained in their Application Engineering bulletin section 21 number 1319.
Dan
try this link for more info
http://www.digitalscroll.com/sb300/portal/home/normal/1
hope this helps
