30xaa leak muffler
good morning guys:
I've been working the machines 30XAA carrier and I have been many leaks of refrigerant in the economizer muffler.
there will be some service bulletin to support elimination economizer muffler?
is very necessary to drive the machine?
Re: 30xaa leak muffler
This is a common problem for 30xa chiller. There is not built a support to reduce the vibration between economizer to compressor. To avoid such incident to be provided an anti vibrator prior to muffler.
I can remove it? I could put in their place?
recover refrigerant.then you can fix it.
