I am overseeing someone trying to commission a system which has just been converted from R22 to R422a or isceon 79 if you like, I have read previous threads and followed the links like duponts website and from what I read something has gone astray somewhere?
system is domestic fridges consisting of 2x walk in deep freeze and 1 veg room. bitzer v/w compressor (original), original condensor, new evaps and TEVs
As per the info taken from the net the new system is running at a higher Discharge pressure 220-230psi but am running into a vacuum on the LP side of compressor, Have expressed dislike about vacuum and the noise the compressor makes when at vacuum only to be told that this vacuum is normal running parameters. which I can clearly see is not from the charts supplied from duponts. I have since adjusted the LP cut out to be above zero but should my LP pressure not be in the region of 30 40 psi to achieve a temp of -4 deg F at chilled room?
any help and any other references would be welcomed.
is there a problem with my compressor and compatibility to gas or am overlooking the system requiring more gas( will my HP press go up more by adding more) one piece of lit says the pressure diffrences between 422a and r22 should be the same or similar.
please help getting desperate:confused:
cheers
Joapers
