Apart from the bigger capacity the AKV will give due to higher SC rates, what's the reason behind this necessity?
Is it to be sure you don't have flash-gas or is there another reason?
Will the valve behave technical otherwise or encounter technical difficulties when running with lower SC rates or no SC at all?
