Re: Bitzer Screw Unloaders
generally the unloaders open a bypass port on the screw length. Disconnect power to each solenoid coil will keep compressor fully loaded. Ramp speed up and down with a VSD would be more efficient, minimum hertz for oil flow is around 30 Hertz
Quoting Magoo. Unloaders simply creates by-pass which means you spend power in compressing and then you by-pass what you compressed ... very poor efficiency. VSD is the way.
Hi Joel404a
Do you not need capacity control for you application? It would be interesting to see the difference between running a lower SST due to less staging VS the Parasitic losses of utilizing the Unloaders.
