Ammonia Refrigeration Lubricants Analysis
Hello,
I am currently doing a project about Ammonia Refrigeration Lubricants. I'm looking to obtain more market intelligenct to better understand what customers are looking for. Responses are GREATLY appreciated. Thank you very much for taking the time to help me out.
Survey:
Company name:
Current Lubricants Products Buying:
Advantages/Value of Products:
Major Competitors within the Market:
Please Pick 4 of the most important qualities from this list: synthetic, pour point, wear performance, high film strength, foam control, high viscosity index, corrosion protection, deposit control, service life, seal/elastomer performance, oxidation inhibition, high flash point, low solubility, low vapor pressure, low wax content, low moisture content
How much does each of the following effect the purchase of oil? (1 -greatly effects, 10 - no effect)
Price:
Lifetime:
Carbon Footprint:
Product Claims:
In-Field Performance:
Test Data:
Warranty:
Supply Contracts/Commitments:
Availability:
Customer Service:
What types of elastomers are being used in the ammonia system?
Overall Satisfaction with current products?
Any suggestions, recommendations, or comments?
If you wish to be contacted further, feel free to leave you name and way of contact for further up questions.
Thank you very much for taking the time to help me out!
Re: Ammonia Refrigeration Lubricants Analysis
You company survey does not translate to forum use very well. :(
Perhaps you should consider how you would complete your 'tick boxes' when you have not provided a suitable template.
Also, posting the same question more than once is not required or acceptable behaviour. :mad:
Trying to place your question in the correct section might also solicit a better response.
