Re: How to get/maintain +17f
If air goes in, It must go out. Its crude but it may work with a supply and return duct. No promises, you need to calculate room cooling load, and product cooling load and compare it to the capacity of the -5F system. You may over cool some of the Roe and not cool some of the roe if you don't have good air distribution.
If you are only trying to transfer energy (no direct air transfer), you can look at a number of options, including heat transfer wheel, closed loop fluid system, thermosyphon coils and heat pipes.
