problems with daikin container
hi there,
I have a problem with daikin container year of produc. 2007, runs with r134-a, scroll comp. first it was low press. alarm, ive changed filter dryer, refilled and it has start to run properly after a while it has start to show me abnormal heat on high press, now the comp, just start for a min and stops. some manuals or sugestions could help me a lot.
best regards.
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
interfrigo_cuki, see post #76 in this thread.
hello to everyone,
need manual for thermoking cfii unit with uPA+ controller
tnx and regards!
ron21gallosa yahoo.com
abbsnowman
Hi reefermechanic and welcome.
I think your calling truck / trailer units container units. On this side of the pond, container reefers are "sea going" containers.
One last thing, you may get some flack for offering manuals here. If you decide to help someone this way, it's best to email them with the offer.
I apreciate your wanting to help but some others may not.
Abbs
por favor me podrias mandar tambien los manuales, ya que soy nuevo en esto, te lo agradeceria.
Help, need wiring diagram SBII, SBIII, imail luisfelipevac@hotmail.com
Can let me know the backpressure of thermoking (-20C)
hi i am new member of reefer mechanic....hi to all
aku
Hello Everybody.
In my country haven't any freezer container and unit factory.
But I am researching to cooperate company who can supply to us freezer container. But, I need to know which way is better?
1st. We will studying workers then installing. /of course we must to purchase reefer machine like a Termo king, Daikin .... etc./
2nd. We will purchase completely product freezer container.
Actually our country is very cold in winter and summer time is very hot. So reefer machine must be work -40 +40C. And my countries climate dry. So reefer machine must be work in bad climate like a storm.
Please tell me, which companies reefer machine much suitable in my country? and how teach my worker?
oh there is one offer about installation inner and outer of container?
Best Regards
Ariunbold.Ts
Hi Ariunbold,
In response to your need to supply a reefer able to maintain -40oc / +40oC, e-mail me:
info@refrigeratedcontainersupplies.co.uk
aku
Hello Everybody.
Best Regards
Ariunbold.Ts
If you need a reefer container able to maintain -40oC to +40oC , e-mail me:
hello everyone!
does anyone have manuals for starcool and the carrier primeline? I am a Reefer Technician working in Dole Philippines. we come across these reefer units but we dont have manuals. any help is appreciated. email me vans@hot-shot.com.
ALL of Carriers container manuals are on their website.
Edit; Same with the Starcool.
Hi. I'm searching high and low for software to allow connection to the Mitsubishi MMCC3A unit on refrigerated containers. It's usually called "Mitsubishi Heavy Industries Data Logger System". Would anyone know where this is available to download? Thank yo very much.
Hi Jon, welcome to RE.
Is this what your looking for ?
http://truck.mhi.co.jp/gen/acrmw/ser...orma/act5.html
call up StarCOOL and they will send you the manuals. They have them on the site but you have to register to get the access.
hi guys,
everythings ok:)))
all the best...
reefer mechanic;)
Hi. Iam a commercial refrigeration tech Electronic . I was just to repair a carrier 12-60028 controller because it's no turn on the system, let me know where I find the manual for get more information about it
mike50
Hi Mike,
Whats the problem? Controller doesn't work or controller doesn't control some components? ( Etc. kompressor, fan motorrs?))
So you cant find any manual about controller on web... :((((
Waiting your reply...
See you..
Reefer mechanic...
Carrier doesn't gives information about controllers or sales spare parts for them. if you can send it to carrier and they will send you a repaired one for about 350EURO.
In other hands you should try if its possible to do a software uprade maybe it's a software/set up problem. For that you need a software card.
Tell us what is the exact problem. Doesn't turn on at all, turns on but nothing happend ...
hi all
iam a new reefer tech ,
i want to thanks all tech persenels her;
i have one quation i have a lap top with windOwz xp tkt 2008;is possible to work tihs windOwz with dataline carrier.AND SMART SPONG THERMO KING.
BEST REGARD
[QUOTE=Vans;214947]hello everyone!
does anyone have manuals for starcool and the carrier primeline? I am a Reefer Technician working in Dole Philippines. we come across these reefer units but we dont have manuals. any help is appreciated. email me vans@hot-shot.com.[/ I HAVE ONE MANEUL OF STARCOOL
I SEND YOU NOW .
BEST REGARD
Carrier container reefer manuals can be downloaded from their public website at
http://www.container.carrier.com
Select Literature in the left hand menu bar
Then manuals on the literature page
Manuals for the last 12 years at least are available direct online with out ID or password
Hi all, I have a Carrier Thinline 69NT40-489, how can I set temperature range so do unit don't run 24/7. I guess what I'm asking is if the unit is controlled by thermostat? Seems like the one I have is always on.
I assume from your request that you are running this unit as a static store in the perishable range - Setpoint above minus 10°C. Under these conditions the unit is set to run continuously to provide optimum temperature control for perishable product. It does this by throttling the compressor suction line by slowly closing the suction modulation valve just before the compressor. In this way the air supplied into the container is controlled to setpoint +/- 0.25°C. The power draw under these conditions is significantly reduced as the compressor, the only major power draw item on the unit, is running light and current could be as low as 8-9amps from a high of 15amps. There is no way using the Carrier MicroLink controller to change this.
adacus1
Thank you.
a pleasant day to you sir now....can u you help me i am reefer technician from Philippines can i have any you have a about reefer that makes me to improve my skills,we handle thermoking/carrier/daikin/Mitsubishi but i dont have any books or any thing abouts reefer just a diagram.
i hope you will help me and thanks in advance sir
lilgenesis_19@yahoo.com....
hey i have a problem with thermoking magnum its supply is going below the set point the set point is -20 and supply is -27 return is -29
hey i have a problem with thermoking magnum its supply is going below the set point the set point is -20 and supply is -27 return is -29[/QUOTE]
was the product loaded at -29 ? It being more frozen should make no difference.
If it was freezing fresh range products then i would be acting.
Hi. Could someone help me identify this ThermoKing model? I know it uses a C201 engine and V style (two piston?) pump.
I can not find the location of the model number.
Here is a picture.
http://www.marswegen.com/frontpic.jpg
It was involved in a cabin fire and the fuel lines melted. I am rerunning the fuel lines but I do not know which line is the return and which is the supply. I would think the supply would go through the filter first. The only place I see this is possible is at a T near the filter, there is a line from the injectors going to one side of this T, The fuel filter is on the other side of the T, and one of the burn off lines at another point on this T.
The other place is on the diesel pump, right under the priming plunger, there is another line that is burned off, but this line does not go to the filters, so I think it is the return line.
what has me confused is the T by the filter. I guess the return from the injectors could possibly refeed into the supply and be refiltered.
the fridge in picture is a snwd 30 = no electric standby
Clivemtk,
Thanks for the quick response. After googling that model, I realize this was an antique that might have been worth salvaging instead of taking it apart. It was complete until I started taking it apart including a very nice chrome grill that I had to save for the man cave. It was last ran in 1997 as marked on the shiney like new oil and fuel filters. The front service doors were smashed in a way that would not allow them to be opened, so it was like a time capsule when I finally got the doors opened. The compressor is locked up, but after disconnecting the compressor, the engine turns easily (I haven't turned it more than a quarter of a turn though, I don't want to spin it arround until I'm ready to turn it over for a while to get oil pressure up). This is my first diesel engine.
I'm not trying to turn this into a "How To". Your answer was all I needed. Thanks for having this forum.
hello all
I'm new here on this forum, am a technician who has + -11 years working mainly on carrier reefers
I've recently started a new company but we are no yet a official carrier dealer.
We have all manuals and part list of the reefers but no service bulletins,
can anyone provide me with the last bulletins or tell me where to find them.
thans and greetings
dear all;
i want cancel alarm H002 for daikin reefer.
tnx.
gravy258
If it was freezing fresh range products then i would be acting.[/QUOTE]
no it was not frozen its was ok whille ago but i dont know wht happen its goes like this...
impossible !!!!!!!!!!!!!!!!!!!!
Hi! All,
I have som prolem with daikin reefer machine, compressor eun verry nosie and can not pumdown how about it?
pls, help me
hi, I have a mitsubishi reefer system that runs for five minutes then stops due to alarm code 413 compressor overheat. Any suggestions on how to solve this problem or what may be causing this?
try checking to make sure the liquid injection valves are opening during compressor operation. Also make sure of hte basics like ***** level and compressor amp draws stuff like that.
next time post more information about the reefer like model and serial number. Setpoint info and other detailed info is needed for proper troubleshooting.
more power to us all reefer man lastly hi to all pinoy ^^
hello to all boss.....i am curious because i have a compressor a new overhaul compressor this is my question the new compressor is running at +02 setpoint in that SP there's no any problem with in 2mos so now i'll change the set point because i want to use my reefer in frozen mode at -25 SP after 3hrs when we conduct a PTI or Pre Trip Inspection i heard a hamming from a compressor and the next is my breaker is trip off and our report is many option and will tell everything what i make in my report.
this what i write in my report and a bases in my experience.
1. Oil in my compressor is low
2. High Ampere
3. Not enough *****
4. Maybe the compressor have a foreign material in the system "but i think that is not a strong bases because the unit is new flashing"
and in myself this is what happen but i did not write to my report in office.
1. maybe the new overhaul compressor is synthetic or local material only.
2. maybe the piston is this allign.
3. over use
the unit is microlink 2 carrier.
