can you upload the manual vor samsung vivace again please? the link has expired and my A/C is gone again.
thanks
[edit]
found it on the yahoo group. thanks.
thanks
[edit]
Hi, did you find the memory code of your A/C?
I need option code for Samsung AQV-12MSAN.
10x in advance.
Hi, this is my first post...
, i'm from Portugal and I have a Samsung SH09AWH unit that doesn't work at all, it has the same problem mentioned in the first post: it has 3 blinking lights in the inside unit (2 green and a red one).
I read this entire thread and now i know i must have the codes to enter in the unit. The problem is that all the links posted had expired except this one (groups.yahoo.com/group/samsunghelp) but it has no codes for my model. From there i ''only'' learn how to enter the codes in the unit.
So can anyone give me, please, the codes for this model. Samsung SH09AWH.
Hi Superswill,
Any chance you could post those manuals again please? My SC09ZW8-SC09ZW8X is caput.
Thanks.
Sorry to dig this thread up again. Iīve been through this thread and a few others and google but canīt find the code for a Samsung SC09AWH. Does anybody have it, please? I am supposed to going to do a maintenance visit today, and the guy from site called me yesterday and said all three lights on the front of the indoor unit were flashing. So it would be nice to go to site prepared.
thanks.
paul..
SH09AWH
2 5 0 2 5 7 0 0 c 8
Thanks Nike123
Otherwise you could try 25025 70340
the sc09zw8, sh09aw8, sh09zw8 alll use that code
or SC09ZA8 010000 1700d9
I've got every code except for the one you are looking for. Couldn't find it in all the ones I got earlier, couldn't find it in this post http://www.refrigeration-engineer.co...66&postcount=6 either
Thanks for the info.
I didnīt end up going to site today, so will have to try tomorrow. Iīve printed all the codes off, so iīll the ones suggested first, then start working my way down the list.
Iīll you guys know which is the correct code.
cheers,
paul
Hello All,
i like to have the codes & service manual for samsung A/C
Thank
I am sure that there is more than one model of Samsung A/C and therefore more then one service manual.;)
Went to site today. The code that Nike123 gave didnīt work, however the code that Paul gave did. So for a Samsung SC09AWH the code is 25025 70340.
Thanks everyone for the help
Thanks for the feedback Airefresco.
I I figured it might, all our a/cs end in an "8", so it might just be a regional thing to say what country it was exported too. So I guess the australian sh09aw8 was the same as your sh09awh.
It was a SC09. What does the difference? Just curious.
I'm surprised nike123s code didn't work then.
maybe sc = cooling only, sh = reverse cycle, but really I don't know. Even when I worked for a place that was their service agent they told me bugger all.
edit: But if so, it doesn't mean much, the only difference is a lack of a relay on the indoor PCB for r/v operation. They sent me craploads of cooling only PCBs without this relay by mistake when I was working there, and they all worked perfectly except for no heating with the same programmed codes.
Well itīs a heatpump, so I donīt know if thatīs right. Nevermind, thanks for trying. Itīs not important, I was just curious.
paul..
Hi all
I have the same problem, can someone please help me . I need the reset code, service manual for sh09bwha thanks in advance
Hello!
Im from Greece and I have the same problem with my samsung inverter aircondition (aqv09fan). I tried to find some help from the greek web page of samsung but I had no luck!!! There are no system manuals that refers to those codes.
If somenone can help me beacouse I have allready called for help twice and they refused to give me the codes.
Thanks in advance!!!
They must provide you with this detail and way how to enter them, because that is not error of unit. It is defect in design, and any decent company should provide you with solution.
If I was you I would call customer protection organization of your country and report that to them.
Codes:
08477717524E for AQV09FAN
09487717524E for AQV12FAN
Ramsan and Stella K,
Here you are... info for AQV09 / 12 FAN.....
Instructions and codes
http://www.mediafire.com/?wcbezuiyyra
grabit while you can
Thank you very much!!!!!!!!!!
No problem Stella.
Apologies to Magna306, but I don't have any info for your model.
Regards everyone!
I have a/c aqv18msax and a problem, turned on my ac first time this year and indoor unit is working normal but outdoor unit wount start (indoor unit is not blowing cold air), ive tried everything from unplug - plug, pressed reset button on outdoor unit, tried all modes, cleaning, but nothing? On outdoor unit electronics are tri leds, red one is on, green is blinking and yellow is off... Anyone has a clue?
Tnx in advance!
hello. i read about these problems with the samsung A/C. i have a AQV 24VBA .is there problems with this? and where can i find the reset codes? i live in Greece and nobody give me codes for it. thanks i am waiting your answer.
Is that a vivace unit?
I can only find an AQV24VBAN
How old is the system?
yes thanks for the respond . yes is a vivace and the right is VBAN as you write.if you have any info please tell me.
Easy if you do a search on this site :D
http://www.refrigeration-engineer.co...7&postcount=13
http://www.refrigeration-engineer.co...9&postcount=37
thanks you . i found these codes. but i dont find how to insert them.thank anyway.
http://www.refrigeration-engineer.co...VBAN#post94215
Look post #12
How did I know that was going to be the next question? :rolleyes:
Dear Friends - I see that you are lifesavers. I have two Samsung AC Units that have failed because of power outages. I need to get the reset codes to make them work again:
AQ09NSAN - brand new
AQV12FAN - one year old - this one is probably listed, but I would love to have them together.
If the service manuals are available, can I get a copy of them? That would be great. They won't give out the codes in Greece.
Thanks a ton,
Guff
Paul, Thanks for the codes. Unfortunately, it didn't solve the problem. Maybe I have another one.
When I plug in the unit, I get one blinking light (the operation light). I thought this meant the codes needed to be entered.
Can you (or anyone) supply further help?
Thanks.
