Both the links are still downloadable. Please check your computers.
thanks for this. Its very usefull.
do you have any one for condensors?
good book thanks
This is very good book.
Thanks for this
HI Guys,
Have any of you came across a technical manual of the vrf FDCA280HKXE4A for mitsubishi heavy industries.I need the fault codes as well as the parameters explanation,eg. 04 compressor dome thermistor.
I couldnt download this book:eek:... Can anybody give me some other links?:rolleyes:
Johny,
Thank you so much for the book!! It's great that you share...
nice book.many thanks.
Thanks for information.I was download it long time ago and it is nice book. today i test the link , it was correct and the siz of the file is 33.8 mb .
best regard
Thanks great one
nice to have it.many thanks brother.
Thank you very much for your great effort.I download it and found it very good book. the link is working well and the book is 33.8 mb .
Thank you
It`s very useful.Thank you very much!
hi johney, thanks.this is very very good book
good source of information,,,,
I have requested answer to the listings on a compressor but so far havnt got any response. could someone please tell me what the chit on an open type CF2Cl2 compressor means to convey by it chit which reads as folls:
Power KW 9
operating temps: -20 c/+40 C/+18 C
Rated capacity 9000 kcal/hour
I would appreciate your assistance on above
thanks
many thnx for the good book :) but what happend to the "standard refrigeration and air conditioning " by ELONKA ????
is it still available ???
thnx, Ice
you read that its working from - 20 to +18 at outtemp of +40, everything above +40 is no longer healty for the system.
grtz, Ice
thanks , icecube51 but doesn't it mean
evaporating temp= -20C
condensing temp= +40C
airconditioning or surrounding temp= +18C ??
In other words the said compressor will cool the air to +18 at a Te or -18 and Tc =40???
Usually two temp values are indicated on the compressor chits but here there are 3 ,,,,bit confusing, ain't it??
it means that this type of comp works within -20 to +18 on evap en condensing is +40.
its not confusing, its nice to have some , normaly when it is on a plate,it is mising or unreadeble.
Ice
Both are very good books, thanks a lot!!
very good!
many thanks!
hi to all its very good book but not down loading how ma i down load this book
Dear friends
I am not able to download the book.
when i click on the link,Another window appears with Nothing written on it.
I am confused..tried 5-6times.
Help required.
Same question to me--can't download.Anyway thank u johny*****.I collect this page first,then when the net goes smooth,i'll download it again.
Thanks for the links to the books. Good stuff
nice book !!!! Thank you
thanks alot
Thank you very much
good book..........thanks...i respeck for u
thaks alot sir...nice book good post
DEAR ALL'IN THE FORUM.
I am installing the Acson mult digital scoll system A/C'S. That is AMDS050B
With this type you need to set the ip address for in door and outdoor communication as well as the pasword. what is is suprising is with the the installation no instruction that you need a password to get the unit going . And the out door unit pc card has 2 little switch which are k1 &k2 . no instruction based on their operation.and on AMDS080 YOU have the switches on the out door unit pc card which are k1 ,k2 k3, k4 .no instruction based to their operation . i don't know why they can't instruct though the manuals . i ask if any one knows about it course we are facing a major problem on commisioning . and most of the time after the setting we exprience some errors on the display device like c1 c- means that commun. error and the machine can not start . thanks .i hope this forum will help me to solve the problem as soon as possible.
Very good book!! Thanks!
Can you please mail me both the books as i can not download b'coz of some error.
I did download it...thank you.
After trying downloading a few days ago, it always appears in my screen a blank white page. Then finally I try to save the blank page...
Mabuhay!!! It's all in there. Many thanks its great...
