Originally posted by herefishy
Pointing the drier down, toward the cap tube inlet certainly does not hurt anything. I expect condensed liquid to be emitting from my condenser, and my condenser actually partially full of liquid, a couple of passes, perhaps.
The drier is referred to as a "liquid" drier, not a "vapor" drier, or a "saturate" drier for that matter. If you have vapor at your filter- drier, and are pointing the drier outlet down so that gravity will assure that liquid (where ever it may be coming from) drips to the bottom (outlet) of the drier, I just consider to be a misnomer. :confused:
I'd say that if you have vapor in your drier, you got other problems, Bub.
Interesting theories. But don't take my word for it. The Prof (Sporlan) may want to weigh in on the drier issue, but for the rest, there is no substitute for testing.
