Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
ust a quick query…..
I have a NT40 reefer used as a static chiller (+5 setpoint), and this has been working well until the last few days when once or twice a day, the power trips at the breaker inside the reefer panel. The incoming mains supply is steady at 385v and everything seems fine. I reset it and it works again. There are no alarm codes. The only change is that the temp here has risen to around +40 in the last few days and this may have an effect.The trip mostly happens in the afternoon when the sun is shinning directly onto the working end of the container.
Have you heard of this happening in the extreme heat ? I am really hoping that its not the compressor windings starting to earth. It’s has the water cooled option but is set for air cooled.
Any wise words please
Can anybody help me in understanding, maintaining and repairing of Thermoking Magnum units?
Whats the best way to handle these units. I'm much interested to learn about them.
Please help me.
shehzad.ahmd@gmail.com
Does anybody out there have the latest Carrier Microlink software, I'm looking for 5155 and 5355 for both ML2 and ML3 Scroll and Recip. I do not have access to carrier website for download. Can someone please email the files to me, greatly appreciate it.
kyniteowl@gmail.com
best regards all reefer mechanics
Good day
I am looking for a data downloader for thermoking and Daikin.
Could you please advise?
many thanks
Re: Big thanks to reefermechanic!
Just wanted to thank Reefermechanic for all his help, he was able to locate the files I needed for my software card. Many thanks!
newjack
kyniteowl@gmail.com
Hi, can anyone help me ?I have a customer with a old TK reefer model TNE-508-34, this reefer is given me some serious problem I am unable to get it to work properly ,I check and change the following all three (3) sensor supply and return,KVQ valve,filter drier, TXV. Check both condenser and evaporator fans, compressor they are all satisfactory yet the system will not pull down to temperature (-25c) the system start up and the pressure and amps are ok and 5 minutes the suction line will frost up causing the pressure to drop off and the supply and return temp also. The following is the info taken from the controller. Supply LH -4.7. Supply RH -5.7. Return -4.0. Evap -4.9. Cond temp 44.5. KVQ setting -55.4. Cool cap 100%. Ambient temp 28.1c. Hi press 10.5bar. Hi press temp 101.2c. Comp amps 10.8/ 10.5/11.3. Can you help me out here if I am doing something wrong or not checking something or is there a TK emergency hot line number .
Thanks in advance
Lynch
reefermanlynch
Thanks in advance
Lynch
Hi Lynch, Whats this unit? is a container, truck or trailer unit? see you. Reefermechanic.
I work in Bagdad, Iraq. The units I maintain are powered by gererators. I have several Carrier 69NT40-541, in which the controllers(micro link 3) have stopped working. The LED is flashing ERR1 or ERR2. Its hard to tell. I have the program card but it doesnt work. Carrier transport reefer div has yet to return phone call. I installed a Dixell controller, it runs but doesnt cool like it should. it is set for -18c but only gets down to -7 or so. I believe the smv is preventing it from reaching temp.
mp snyder
hi mp snyder, carrier has shared new version of software for ERR1. Pls contact by your service locator. good luck.. reefer mechanic..
reefermechanic
Hi Michael, lucky man for today;) pls check your e-mail;) see you. reefermechanic.
thanks guys i need "Ml3_serail_number.bin" so i can program my pc card.
Hello,I need service manual for Thermo King V-300 Max - electro schematics of the electrical board. Does anyone have it?
I am having an issue with a TK CRR-40 with a mp-3000 contoller. It showing "Flash Load". What does this mean?
mp snyder
Hi mp snyder you have to update the software. do you know how can do that?? see you reefermechanic
Hi guys, If you need laptop and communication programs and also connection cable for transport units you may contact with me.... For truck, trailer and reefer container units of Daikin, Carrier and Thermoking units. see you.. reefermechanic
Send me a PM
Hi reefermechanic,
I am having a problem with my Thermoking Reefer container and I was hoping you could help. I have a 2003 Thermoking Magnum unit with a MP-3000 controller. The unit is always set for the same temperature 13.3C or 56F. Recently the container has been going into defrost mode and sort of getting stuck there. To try and stop it, I set the 24 hour defrost to ON, and now it will go 24 hours and then get stuck in defrost. By "stuck" what it will do is go into defrost, heat the evaporator to 86F (aprox 10min), shut the heaters off, starts the compressor, runs for 1 min, goes back into defrost, and on and on. Checking the event log it shows Timed Defrost activated, then ended. These defrost cycles continue with intervals of 7-15min between. I have ran Full PTI and all of the temperature sensors seem to be working correctly. What could this be? I am completely stumped!
Thank you in advance,
BananaNick
BananaNick
Hi reefermechanic,
BananaNick
Hi Bananick , Pls check the sensor test on "manual function test" within "PTI COMMAND" MENU. Do you know how can do that? I think defrost sensor/evaporator sensor is defective. Run the sensor test on manual function test. than check the sensors for 5 minutes.. And watch the all sensors. All sensors measurings must be same. Pls check that's and back to me. see you . Reefermechanic
hi there, can i have some thermoking and xrios 500 service manual/ wiring dia gram.
khalidmz786@hotmail.com
thanks
khalid
BananaNick
Hi reefermechanic,
BananaNick
Hi banana, pls make a manual function test to the "sensor check" and pls note the all values of sensors. Maybe defrost sensor has been failure... good luck.... see you... reefermechanic.
Peace,
I have a case of 1 unit 40ft Reefer Container (with Daikin System) shipped with consignment of vegetables with setting temperature at 0 Deg C, however, at sometime transit, noted several alarms/code D type and there on supply temperature went up between 10 to 16 Deg C (From Data Logger). What caused malfuctioned ? Also noted, 2 drain plugs, one at front end and one at door end not inserted. Please help !
Hi there. I am hoping someone can help me, I am having a go for the first time at fixing a refrigerated container, the only details I have is its a "Celsius 3220" if any has had anything to do with these before I am after a service manual or a wiring diagram for it, someone has done something nasty to the wiring and it doesn't like to run real nice. so anyone can help I would be very grateful Thanks
Hello reefermechanic,
I am new on this forum and new in refrigeration jobs.I need a help about how to log in "TransCentral" section of www.container.carrier.com and download all softwares versions for ThinLine,EliteLine and PrimeLine controllers.Thank you in advance
[QUOTE=Ahmad Osman;285415]Peace,
I have a case of 1 unit 40ft Reefer Container (with Daikin System) shipped with consignment of vegetables with setting temperature at 0 Deg C, however, at sometime transit, noted several alarms/code D type and there on supply temperature went up between 10 to 16 Deg C (From Data Logger). What caused malfuctioned ? Also noted, 2 drain plugs, one at front end and one at door end not inserted. Please help ![/QUOTE]
good day,
for this unit daikin there are two sensor supply but that not possible to change if this unit is full.
not:but those alarms are not afect cargo,if you went to change those sensors you mast to decharge the cargo from container.
best regards
GoksPeks
hi gokspeks,
only authorized users can get download the softwares on web of carrier.
see you
reefermechanic
Thank you reefermechanic for response.
I have one more question for all forum's members.-Does somebody have an user guide (step by step) how to configure controller's software versions for Carrier reefer containers. Or,give me please link to download it.
Thank you
GoksPeks
Thank you
hi gokspeks
if you want , I can talk about that's via Skype.
reefermechanicsh
see you
reefermechanic
Hi ,
I have one of daikin lxe10e-15a problem of frequently defrost 2 hours per time.Defrost setting is 99 hr at frozen mode . before in range , again defrosting. What is problem?
Hi reefermechanic,unfortunately I have no internet access all the time,because I am currently onboard.I have operation manuals of all reefers,but I need service manuals and additional service tutorials about Carrier troubleshooting.Anyway,if you are willing to help and send some useful information you can do it on: pesicgordan@yahoo.com
It will be appreciated so much.Thank you,have a nice day
Thein Htay
Hi ,
Hi Htay,
Pls check to the EIS and EOS ...
Good luck.
Reefermechanic
Hi reefermechanic, i want to ask about code alarm F3 @ cabin controller thermo king KV-300 II MAX
Thanks before :)
Hi reefermechanic
i want to know if you have a software or something for the diagnostics of Thermoking Sb210, 230 and 330. Im looking for service and repair manual of thèses units. I have like 20 of thoses units and we are starting to do the repair and maintenance on them but im not able to find information. Can you help me
Thank you. My e-mail is daniel.racanelli@Hotmail.com
Hi reefermechainc
I have one of thermoking MD 200 used Driver Operation-TS Series Truck Unit problem of frequently defrost.What problem?
Thank before.
I'm using Thermoking MD 200 with Driver Operation TS Series Truck Unit, it is meeting a problem of defrosting frequently .
What's problem ? Could you please let me know ?
My email : nguyenmockhiem2@yahoo.com.vn
Thank in advance !
Best regards,
Khiem
Hi there!
I have a Carrier 69NT40-511-12 problem. When starting up the HP side immediately shoots up to about 2300 kpa. The compressor then cuts out and short cycles like this until it overheats. I weighed in a new charge as on the nameplate but the problem persists.
When I close the suction service valve almost completely the unit runs for a few minutes until the high pressure rises too high again.
I noticed the suction pressure seems too high if the valve is backseated about 200kpa. Also the liquid level in the receiver drops very quickly upon startup
I have no experience dealing with Suction modulating vale and suction solenoid valve. Are these causing the problem?
Thanks in advance
Hi , help me please to find marine reefers communication software.
Daikin Container Communication System (DCCS for DECOS III G)
refmaster
Hi refmaster
whats the problem?
see you
reefermechanic
Mr. Reefer mechanic help me. Give me please manual for daikin LXE10E 149g ;( this is my email address refmaster@ukr.net
refmaster
pls check your mail box.
see you
reefermechanic
I have a problem with removing files from the refrigerated container Daikin LXE10E 149g controllerDECOS IIIG
I have a program DCCS ver.8.00 ,but it with this controller does not work.Сan you have a newer version?
many thanks.
Thermoking Magnum Plus 203 service manual
Hi reefer mechanic, I recently joined on-board a container ship. We usually loaded Thermoking reefer containers especially the MAGNUM Plus 203 series and Carrier 69NT40 series. Could you please send me a copy of its service manual? My email is: johnel.aguasa@gmail.com.
Also, could you please advice me on how to clear the datalogger alarm dAL81 of 69NT40 carrier unit?
Thanks in advance. :)
