Help needed in Venezuela.
Greetings from a Brit in South America. I think your forum is great, and regularly look in to pick up some good tips. Thanks.
Most of the equipment in this neck of the woods is prehistoric, but it's fun to keep all that old junk running. However, I've got a problem with a real dinosaur.
Here's the story:
40-ton open compressor made by a Spanish company called Ramon Vizcaya some 35 years ago. Chills water that cools red hot metal in a tool factory. The system is simple - the only controls are an oil pressure switch and high/low pressure refrigerant pressure switches. No computers, just great big knobs to turn it on and off.
Changed the expansion valve last year, and had no real problems at that time.
Last week the mechanical seal on compressor side of the drive shaft between the electric motor and the compressor started leaking. Customer's own mechanics changed it after I removed the R22. They do all their own mechanical work, and only call me for refrigeration-related stuff.
I returned to recharge the chiller and top up the oil when they had finished. It seemed to take longer than I expected to pull a vacuum, but I didnīt think much of it at the time.
However, when I started to charge the R22 into the vacuum (with the compressor turned off) I was surprised that it wouldn't pull the refrigerant out of the cylinder in a 90F environment.
All valves open on the compressor, guages and cylinder, but the R22 was going in r-e-a-l-l-y slowly.
Checked cylinder pressure - OK for the temperature. Rechecked valves - OK. Checked hoses . OK. Rechecked system pressure - couple of PSI only. The only two service valves are on the compressor itself.
Started up the compressor to try to pull in the refrigerant faster and the oil seal started leaking oil again. I'm not sure if they fitted it wrongly, or if it was the wrong seal, however while they get a new seal, it's given me some breathing space to think about why the system won't suck in refrigerant, and why it took so long to pull a vacuum.
Any ideas?
Saludos
El Tel.
Re: Help needed in Venezuela.
I had a hose problem similar to yours. It was on older hose and when it was opened to the vacuum the rubber lining in the hose collapsed and twisted restricting flow. First i disconnected the hose and blew some gas through it with no apparent restrictions. Reconnected it opened it to the vacuum again and opened the bottle and still had reduced flow. It was a 1/4'' hose so I switched to a 3/8'' new hose and it charged normally. I did not discover the loose liner until I tried to use it to pull a vacuum on a Small Copeland compressor and the lining came out in pieces. So I cut the end off and it makes a nice oil draining hose. I don't work on halocarbon systems very often so my hoses tend to be neglected and I have been known to run some ammonia through them through them once in a while in a pinch. I know it is not good for them, but i purge them with air till the stink is gone.
