Which refrigerant to use for low temp apps?
I am asking this for another Dutch guy who also wants to build a refrigeration system for his processor. He cannot ask it himself over here since his English is even worse than mine.
He plans on building a system where the refrigerant evaporates in an evaporator directly on the CPU die. Depending on how my experiments with a TEV in such small system work out, the evaporator will be fed by a TEV, captube, or fixed evaporator pressure valve.
The question is: what is the best refrigerant to use for an evaporation temperature of approximately -40 °C, preferrably -50 °C? He says he can choose between R22, R404a, R407, R600a and R134a.
To me, R600a and R134a seem unsuitable since compressors are not optimized for those low suction pressures. Another problem is the rather low evaporator surface (he did not yet finish the design of his evaporator, but I guess the refrigerant->metal contact area is not larger than 0.05 m<sup>2</sup>), so a refrigerant with a high heat transfer coefficient and high latent heat of vaporization seems to be more optimal.
Based on this, I would say either R22 or R407, but my thinking proved to be wrong many times earlier.
