Any advice how to cure this blocked system?
I'm working on a commercial freezer with a semi hermetic compressor marked J&Hall, 4hp. There is no oil separator. I don't know which gas was put in by the last engineer or which oil is in there. The gas leaked out of a damaged tube . I charged it with 22 but the expansion valve is blocked. The sight glass shows the gas a dirty red and the smell is bad. I'm thinking I should change the oil and charge again with 22 . Which oil would be best and what would be the best way to clean the system? Or any alternative advice ?
