Im sick and tired of hearing people spouting off about superheat settings and the correct way to commission a valve. Every explanation or method ive read in books, magazines,web sites etc seems to differ. The more i read the more confounded i become.
My question is this.
Where is the best position to take our td readings? Outlet of the tev and oulet of the evaporator coil.......or outlet of the evaporator coil and saturation temperature/pressure at compressor suction valve? Surely they are different and which one is correct???? Also why is it that on modern Japanese splits which are pre charged the valves are preset no matter what the length of pipe run? It can be anything between 10-30m but the valve setting remains the same as there is no adjustment necessary according to the pioneers.
Whose first to put this matter to sleep??
