Continue theme Bearings Frick XJS/XJF 95-151
I have overhaul compressor XJS 120 and finished work installation jackshaft. New bearing SKF factory with mark YOR.534B0101H24. I measured axial play and saw standard in play 0.025 mm. for 2CL series. Why then in service manual I see two different a picture: between a bearings two shims (any for install) and picture without a shims. After installation any we will be reduce the gap. What must be gap (axial play) on jackshaft, after close housing of shaft seal...?
Kind regards
