newest member
hi guys,
i'm new member in this comunity. so i need u guys guidiance and help. i'm actually involving in this HVAC & Refrigeration industries but since i'm new so i need a lot to learn and i'm very appriciate to everyone who willing to give me a hand (^_^)
thanks & see u guys later
Re: newest member
Hi GiGas and welcome to the forum.
If you need help then don't be afraid to ask, plus any information you have to share is always welcomed too.
Re: newest member
Hello,
A warm welcome from Belgium.
Don’t hesitate to ask any question and share your knowledge and experience with us.
This forum is read worldwide and you may expect a professional answer.
May I ask you to add also your location to the RE Members Map?
You can find it in the Green Top bar, the lower line.
If you post a questions with the units you’re used to work with, place between brackets the other units. So if you normally work with SI units (bar, °C, m³/h..), place then between these units the proper IP units.
You can do the conversion with a free software program Uconeer
You can find it on http://www.katmarsoftware.com/uconeer.htm#download
Or you can use the spreadsheet of Dan posted on http://www.refrigeration-engineer.co...0617#post50617 post 6.
When you have a technical problem, try to post as many as possible readings you have made. You will see that we need many times condensing and evaporating pressure; discharge, suction, evaporator outlet and condenser outlet temperatures. Try to measure these very accurate.
The better you measure these, the better we can help you.
Note also band names, types of all the items installed in the installation.
I hope that you stay a long time with us and that you can contribute to expand this forum.
Peter
