Hello,
i'm looking for a Howden XRV163-1.65.
Back here in the Netherlands there is no XRV available.
It may be a running machine, or scrap, and we will do an overhaul and make it run again.
Regards, Gerben
Hello,
Regards, Gerben
Maybe SES international can help, they are located in Delden
http://www.sesint.nl/index.php
Other than that, you could ask Howden
http://www.howdencompressors.co.uk/
If you need Howden XRV163-1.65 screw compressor capacity controller Type FKD40A + FKD41A equivalent to Danfoss make EKC30 + EKC31 please write to info@manikengineers.com They are regularly supplying to Kirloskar Pneumatics Ltd. who are manufacturing these screw compressors under lience from Howden UK for past 20 years.
Hi, Anand :)
I do not want to be rude, but do you feel you push little too much :eek:
http://www.refrigeration-engineer.co...0002#post50002
http://www.refrigeration-engineer.co...0884#post40884
Originally Posted by anand
http://www.refrigeration-engineer.co...8352#post38352
Maybe I'm not right but let's hear other guys;) Yes, sometimes we try to help with some links, but....Quote:
Best regards, Josip :)
http://www.howdencompressors.co.uk/xrv.htm
Howdens XRV site. I'll send you a PM
Ken
Hi anand:)
Did you know that Kirloskar did the early XRV casings. Massive amounts of failures, put a lot of people of XRV's for good.
Casings are now made elsewhere and the problem has stopped. I am told the XRV is now quite a good compressor.
So for your referance I would say no thank you;)
Stop advertising on the cheap:) as we say in Ireland pony up:D
Kind Regards Andy:)
