Can anyone help. We have an installed 2 wall units running off 1 outdoor. A wired controller. The one with the controller operates but the other doesn’t. It’s getting power and pulse. Daikin tech is useless with help
Have you the controller paired to both units? Are both indoors compatible with the outdoor?
The controller connects to one unit p1&p2 then the 4 core goes from one to the other unit according to Daikin but only the one with the controller connected to it operates. It’s as if it needs to be set to master and slave but can’t figure out a way
Model numbers might help
Go into setting mode 21 and set code 0 to 02
https://www.manualslib.com/manual/18....html?page=103
Users start by inputting their outsourced it services priorities and preferences into the AI system. For instance, someone interested in purchasing a smartphone might prioritize a high-quality camera, ample storage, and a long-lasting battery.
