City Multi Change temp sensor position on PEFY-P100VMHS-E
Guys need to change return air sensor position from factory default position to wall control
Being city multi it needs to be done by dip setting at the fcu.
Can we confirm dip Sw1 No.1 to on?
Re: City Multi Change temp sensor position on PEFY-P100VMHS-E
Mavricks Choice
bloxd io done by dip setting at the fcu.
The static pressure setting is adjustable by changing a dip switch. The default setting is 0" W G, with options for 0.12" and 0.24" W G.
Mavricks Choice
fnaf security breach
The SW banks should still match up, SW1 listed on the sticker is the correct bank but the dip switch number could be incorrect.
