Ben23
Been asked if I could install a wall mounted system to provide heating for winter and cooling in summer time for a small barber shop. Room only needs a 3kw unit at most now he’s getting a bit nervous with it as 3kw sounds like a lot of power but I was trying to explain it doesn’t actually use 3000w an hour it’s inverter driven and will just maintain a set room temp.
What is the wattage of each heater as that's also important. If he is using 2 x 3kw electric heaters, with them both on full you will use 6kw per hour and get 6kw per hour of heat out of them. An air con unit will use 1kw and give 3kw back out so make sure you have done your load cals correctly.
I’m right in thinking it’s going to cost less than the 2 electric radiator things he currently has that cost him around 5-6 pound a day to run. Plus they can’t cook the shop in the summer. Is there any rough way of working out running costs of a/c I know it’s going to fluctuate a bit.
It’s not a over crowded place he works by himself and max maybe 3-4 people in there at any one time so nothing too major.
