Is there a difference between the two? I hear "scroll" when referred to refrigeration and "screw" for air compressors...are they the same?
NO, scroll are spirals rotating one into the other.
http://www2.mat.dtu.dk/info/experien...rollindtag.jpg
Screws are two counter-rotating shaft.
http://www.compressor-spares-manufac...-servicing.jpg
No. They are completely different types of compressors. The avatar in my response shows a twin screw compressor.Quote:
Is there a difference between the two?....are they the same?
A screw compressor consists of rotors that mesh together. As the rotors turn they create compression (low pressure/large volume to high pressure/low volume).
The scroll compressor works in the same manner, except the compressor consists of two plates that rotate together.
The links below show some basic details of twin screw compressors:
http://www.greenbusinesscentre.com/D...ompressors.pdf
http://www.copeland-corp.com/cp_rf/p...cts_scroll.htm
Here is some information on screw compressors:
http://www.copeland-corp.com/cp_rf/p...ucts_screw.htm
http://translate.google.com/translat...%2Findex%2Ephp
http://www.carlylecompressor.com/cor...I10562,00.html
Some larger screw compressors. These are a variety called a single screw.
http://www.vilter.com/pdf/VSS_final.pdf
There also some three rotor screws deing developed, but I can't seem to find any links right now.
Scrolls tend to be small or medium size while screws are generally large.
it's similar type but both one become covered each other.
