Recommendation for Reverse Pipe Split Unit
Hello,
I am looking for a split ductless unit around 9000 BTUs, only need it to cool, and is easy to reverse pipe. Using a left hole is a direct path outside, going right runs me into the garage and behind large built-in cabinets. I would like some recommendations of units that are easier than others installing the drain and ac lines using a left hole.
Re: Recommendation for Reverse Pipe Split Unit
To the best of my knowledge, all the major brands' wall-mounts allows for pipe routing either way, certainly true for Samsung, Daikin, Mitsubishi, Toshiba...
:cool:
The Viking
:cool:
Thanks, I was concerned that a certain brand will work reverse piped, but won't mount flush against the wall or running the coolant lines from the left is a nightmare with brand X
