Hi Guys
Does anyone know where to by the above fittings that connect to the danfoss KP5A pressure switch capillary ??
Hi Guys
Hi Quality
You can get them from Dean & Wood or Climate Centre code no 060-0078 plus adaptor code no 060-0141 Kr Glenn
I can`t seem to find anyone who sells the fitting on its own. Dean & Wood don`t I will try climate tomorrow
You can make it yourself by brazing the right parts together, it will save you time and money.
Hi Quality
Those are spare part code nos and they do sell them , quote those numbers
Thanks, can`t braze because its for ammonia
Hi Quality
I think what Chemi means by brazing is silver soldering, you can use Blue tip silver solder to weld steel to steel for Ammonia as long as you make sure it is clean and you use No 2 flux and the capillary protrudes about 25 mm inside the tube.
The standard Danfoss capillary lines come with a fitting on either end (060-116166), if you need to extend the length get some steel hydraulic tube cut the capillary and silver solder the extension in.
Danfoss also sell the weld nipples that have the nut (060-116266).
Paul
I managed to track some down the new part number is 060-1064 that's for the 1/4 npt x M10 x0.75 fitting and little aluminium gasket
