Re: Refrigerated Pie Case
No not really.
Pies tend to be in the deli section with mixed meats and
other products, also pies are pastry crusts so the different
materials combined just need treating as a deli case.
Loose raw meats dry out if the case has too large a temperature
difference over the coil, but loose cooked meats in a pie crust
would react differently.
Just store at normal deli case temperature and follow food
manufacturers stated guidelines.
Rob
easiest way is to check the wiring diagram - if theres no humidi stat then no
It seems, he worked on them when he was 13 years old. Pretty good work ethic, LOL
