Xarios Micro plug terminal removing tool
Hi I have a micro plug terminal that is losing connection under load and need to replace the single terminal in the multi-plug. Does anyone know if the special tool to remove it is available from say RS or Farnell or is it only available from Carrier? Thanks
Re: Xarios Micro plug terminal removing tool
Link it out,take the back off the micro solder a wire onto the inside bring it out and join to harness that's what me and quite a few others do,normally it's the evap fan wiring that gives problems
