Hotpoint FZA54 ice build-up
Had this freezer for a good few years now. Started about 2 years ago where the 'High temp' light came up so looked online which resulted in removing the back panel to find a load of ice built up at the bottom. Melted the ice and a year later (last year), the same thing happened. Then 9 months later (about 3/4 months ago), the same thing happened. The same thing is now happening again and I'm worried this is becoming too regular.
Any tips?
Re: Hotpoint FZA54 ice build-up
Hi Clubba It sounds like the insulation of the cabinet has failed and the Ice build up acts like a heat sink. This will only get worse and cost you a fortune in electricity due to excessive run times of the compressor. Suggest you find a replacement cabinet Kr Glenn
