Hi everyone,
I need the samsung option code for AQV09UGEN (for the remote controler).
Thanks very much.
Hi everyone,
Thanks very much.
OK,
Let's make sure I get you the right code,
Are you after the option code to enable a wired or upper level controller to be used?
OR
Have you changed the unit's circuit board and need the unit's product option code to be programmed via the remote controller and, if so, what type of controller do you have?
:cool:
I changed batteries' remote control unit.
After that, I taped a code for a similar model AQV09UGAN.
But it was not good
But it was not good
My model is AQV09UGEN
OK,
But if you just changed the batteries of the infra red remote controller then there isn't any need to enter a code...
Does anything happen if you press the ON/OFF button on the remote?
If not, look at the IR transmitter at the front of the remote via a digital camera, like the ones found on a modern mobile phone, does the IR transmitter blink when you push the buttons?
:cool:
Yes but I entered the code 044777 - 17d20d, the remote controller unit didn't function.
And lamps on indoor unit are continuously flickering
And anything happen if you press the ON/OFF button on the remote
When I press the ON/OFF button, I can read
SET and fan icon
But the air conditionner don't work
SET and I see a fan icon
But the air conditionner don't work, air flow blades are closed
OK,
So the screen on the remote changes but does anything actually happen on the AC unit itself?
If not, see post #5 above about using a digital camera to check the IR transmission and let us know the result.
yES, the screen on the remote changes but nothing actually happen on the AC unit itself
And the IR transmitter is blink when you push the buttons
And the IR transmitter is blink when I push the buttons
OK,
Have you tried the ON/OFF button on the indoor unit itself?
If that didn't do anything, try pressing the K3 button inside the outdoor unit.
I tried the ON/OFF button on the indoor unit itself and that didn't do anything
But where is the K3 button inside the outdoor unit ?
It's raining and it isn't possible to reach the outdoor unit now.
I will try when it is possible and I will recontact you.
Thanks very much
