Re: Duopack gea il problem
cdelefor,
Not sure if they are exactly the same, but they do have occational problems here in Australia.
There is a supposedly more efficient oil separator out now indicating 5ppm ol carry over.
The ones I have seen have a large number of small filters in a circle using "0" ring to seal on ID of filter.
How long have your coalesces been in service?
If reasonably new, sometimes "0" rings do not seal & have made rubber gaskets to seal on end faces of each filter.
Hi cdelefor.
Ranger is on to something there.
When I first read your post I thought of a Sabroe pack that threw oil over for a pastime!
The cause turned out to be a poor O-ring seal on one end of the coalescer.
With a new Filter the oil carry over stopped over night.
So what's stated could be very relevant.
Hi cdelefor,
what type of compressor is it, medium? large?
are they fitted with suction check valve (new design) or not?
what is your minimum driving speed with inverter together with minimum slide valve position?
