Differential temp drop across FCU - affects pressure?
Maybe a dumb question...but does the 7degs differential temperature drop give a large pressure increase across the FCU coil and ultimately the return leg?
If this is correct - would a differential pressure control valve help to control this increase ?
Basic answers please!!
Many Thanks
Re: Differential temp drop across FCU - affects pressure?
Having trouble undersanding what your asking here.
Are you saying your evaperating coil has 7 degrees diffrence from inlet to outlet?
Could you define return leg?
A TEV will automatically adjust to maintain superheat.
no not correct, you need proper air balancing
