Charging a Mitzi City multi
Hi there, looking for some advice I'm working on a Mitzi City multi and am now trying to charge with additional refrigerant, I need to add 60kg to the factory charge, but the problem is I've added 42kg and can't seem to add any more, any suggestions as to how to add the remaining charge.
Re: Charging a Mitzi City multi
thats a lot of additional charge- is the pipe calculation correct?- if it is, get a 20k bottle of gas and charge it via ur reclaim rig whilst the unit is running in cooling mode
That is, as stated above, one heck of an extra charge.
Have you double checked the room leakage safety factors as well?
think the condensers sited in cardiff-33 miles along the m4:D
install monkey
As install monkey says, use your reclaim machine to push it in or close the liquid line (pump down) and the suction pressure should drop enough for you to be able to get more in.
1 Attachment(s)
Its wrong answer)))
Try like that
Attachment 11397
