ChrisMowatt
....... No installations instructions came with the heat pump or they have been lost.
When I turned on the heat pump for the first time the controls went through the start up process, turning on the pump for the external loop first and then the pump for the internal heating circuit. After a short period the LCD reports error code 001 and beeps. The compressor is not turned on.
I guess error code 001 is insufficient water pressure in one of the circuits, but I am confident the flows are good in both circuits. I suspect that one of the sensors has failed or become disconnected from the control board.
I bypass the control board and connect the compressor directly. The compressor works and the heat pump starts to produce heat in the heating circuit and the outflow in the cooling loop is significantly cooler than the inflow. So far so good.
After an hour a frost starts to develop on one of the accumulators. Is this normal or does it mean that there is insufficient flow in the loop to the low grade heat source?
How should I go about diagnosing the 001 error code? What is the most likely cause?
Any advice much appreciated.
Chris
