Re: metric capillary tube
Could be 'c' but also was the end of the captube burred at all?
Hi Tralex:)
0.040 Thou is near enough 1mm, or at least thatsthe guide I use.
Kind Regards. Andy:)
Thank you Andy and Brian_UK.
The end of the captube was clean and not oval.
Now I knew there are captubes with same outer diameter and different inner diameter. How I can check inner diameter without pin?
Does anybody know some link on the European norm or ASHRAE document ?
Hi Tralex:)
to be honest I have never felt the need to measure a capillary ID. They come in a roll, with the ID tagged on it:D
File a pin down until it fits the ID (widest part of the pin) and stick it in a micrometer to fine the diameter of the pin.
Hi Andy :)
It's good idea. I'll do it.
Thank you very much.:)
