Re: Criocabin freezer room
From vague memory, the ceiling sits into the wall panels, remove the wall and corner pieces and it will come out depending on if silicone was used to install.
Unlock all roof cams, unlock one wall and corner pieces, you'll need to lift the walls to remove from the floor.
Alec
Thanks Alec, I can only access the front (door side) and left hand side wall, the back wall is up against a fence and the right hand wall is up against another cold room. Hopefully I'll have enough room to lift it off the base.
