pollution in my power plan
hi to every one
i work in steam power plant
and the pollution rate is very hi
http://im35.gulfup.com/Nm8qz.jpg
http://im33.gulfup.com/ct3Nm.jpg
Re: pollution in my power plan
Do you have chimney sweeps in Iraq? :D
turn a few generators off- sorted! :o
install monkey
hahahahahahahaha
Wow!! makes you wonder why we bother with a little carbon reduction you are throwing chunks into the sky.
If oil fired, the injectors are over injecting and need replacing or air ratios are too low, if coal fired.. feed rate too high and fire bed too thick, or air ratios wrong, if getting a lot of clinker in ash, low grade coal.
There was me thinking I was destroying the world by leaving my tv on standby !
hookster
this pollution happen every day and take about 1 hour to finsh
then the it be more cleaner
i asked some of the engineer in the power plant
why they not treat with this problem
they answered me
(before the Iraqi invasion of Kuwait
we used fuel addition which make the carbon and soot
very little
after the invasion
these addition were prohibited due to mass destruction program )
Magoo
that right
jonjon
hahahaha :D
have u considered pv panels? haha
check the running current of that 2 ton craft unit!! :D
install monkey
what you mean by (pv panel)
install monkey
hahahaha
:D
Hi, kefah :)
kefah
probably PhotoVoltaic panel .... you have a lot of sun .... good idea ...
Best regards, Josip :)
Josip
Hi, kefah :)
you are right
we have sunny days most of the year
and temperature reached 46 C yesterday
